Mack Posted February 27, 2009 Share Posted February 27, 2009 Hi Has anybody installed TC on a Defender? what would be main issues to modify? opinions and jokes are welcome. M Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 27, 2009 Share Posted February 27, 2009 Main issue would be about £2000 for the bits maybe more (the modulator is over £1000 new, plus speed sensors, plus new brake lines, plus ECU... wiring ....) for which you could get a set of proper lockers and quite a lot of change Quote Link to comment Share on other sites More sharing options...
101sean Posted February 27, 2009 Share Posted February 27, 2009 Retro fitting ABS/ETC to a defender would be hideously expensive. Needs ECU, wiring loom, ABS modulator, sensors (4 of @ £250 each ) top swivel pins, CV joints, rear hubs etc etc. So that will probably be a no then! Mine is factory fitted and it's very good but dread it going wrong (at least it's not a Disco II ) Quote Link to comment Share on other sites More sharing options...
101sean Posted February 27, 2009 Share Posted February 27, 2009 BM beat me too it! Must type faster! Quote Link to comment Share on other sites More sharing options...
Mack Posted February 27, 2009 Author Share Posted February 27, 2009 Quite clear then. Thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 27, 2009 Share Posted February 27, 2009 Fiddle brakes can be very useful (and cheaper), 4-wheel fiddles would give you the functionality of ETC on a very, very basic and labour-intensive level. For ~£1000 or less you can fit axle diff locks both ends and then that's about as much traction as you're going to get. Quote Link to comment Share on other sites More sharing options...
rallycinq Posted February 27, 2009 Share Posted February 27, 2009 About £35 a month in gym membership to improve flexibility of your built in traction control device (ankle). Cheers David Quote Link to comment Share on other sites More sharing options...
western Posted February 27, 2009 Share Posted February 27, 2009 or learn how to Cadence brake explained here & here Quote Link to comment Share on other sites More sharing options...
