wib Posted February 28, 2009 Share Posted February 28, 2009 Anyone know how two get the emissions down Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 28, 2009 Share Posted February 28, 2009 You will probably get a better response if you share what type of vehicle, age , engine etc.... Basically a well tuned engine will have appropriate emissions.... The people on here have a wealth of knowledge, but they need something to work with. Neil Quote Link to comment Share on other sites More sharing options...
gemsdad Posted April 22, 2009 Share Posted April 22, 2009 You will probably get a better response if you share what type of vehicle, age , engine etc....Basically a well tuned engine will have appropriate emissions.... The people on here have a wealth of knowledge, but they need something to work with. Neil hi,i had a problem with slightly high emissions,i used a product called cataclean,this worked for me and reduced the emissions enough for the mot,i hope this is of use to all members. Quote Link to comment Share on other sites More sharing options...
kmm Posted April 27, 2009 Share Posted April 27, 2009 I had my Rangie fail on high emissions. My mechanic guy restricted the throttle cable so it wouldn't rev very hard and it passed ok. Mine is a deisel Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2009 Share Posted May 1, 2009 If it's a diesel, then add 20% cooking oil to the fuel tank. This makes a big difference to the emission readings. Les. Quote Link to comment Share on other sites More sharing options...
kmm Posted May 3, 2009 Share Posted May 3, 2009 If it's a diesel, then add 20% cooking oil to the fuel tank. This makes a big difference to the emission readings.Les. Used or unused cooking oil, does it matter? Does the cooking oil clog up anything? Kenny. Quote Link to comment Share on other sites More sharing options...
manxrover Posted May 6, 2009 Share Posted May 6, 2009 Used or unused cooking oil, does it matter? Does the cooking oil clog up anything?Kenny. Hi. It did in my 97 RR clogged all the filters, and took three filter changes before it cleared and started running with no smoke ( smelling of chip fat ). Might be the problem with high emisions, can you see or smell any odours from the exhaust. Brian Quote Link to comment Share on other sites More sharing options...
landybehr Posted May 6, 2009 Share Posted May 6, 2009 Anyone know how two get the emissions down find the reason why it fails if it´s a petrol engine car .. worn piston rings/oil consumption, Cats aged/not working, lambda sonds failing, timing out, distributor worn, spark plug/wires bad, .. some good structural information about the emissions with petrol fuel is here, by reading of which you´d know how to help the vehicle resp. how to cheat (not that that´s recommended in your own interest, when it fails sth. is wrong and certainly mpg suffers or hardware too. If you drive the car lot of miles and the need for MOT indicates that it´s not just a Offroad-Toy then long term really pays to make it right) http://www.megamanual.com/ms2/tune.htm#emissions Quote Link to comment Share on other sites More sharing options...
