minivin Posted February 21, 2006 Share Posted February 21, 2006 Ok, got caught out, so here are the part numbers if you need them in the future: Mainshaft with large drive gear, taper bearings within drive housing; TRI/LM29749/10 Drive Worm Gear Shaft, taper bearings within drive housing; KLM67048/10 The first main part is for the Cone part number, the 10 on the end is for the Cup profile ie a KLM67048 Cone has a KLM67010 Cup Now to order a drive worm bearing Link to comment Share on other sites More sharing options...
