PITBULL Posted March 1, 2009 Share Posted March 1, 2009 how much lift do u need to run 35's on a rrc Quote Link to comment Share on other sites More sharing options...
timmymac Posted March 2, 2009 Share Posted March 2, 2009 i run 35"s on a 2 inch susension lift and 1 1/2 inch body lift with trimmed arches and would sujest this way. you will also need a different wheel offset too. it may be possible to not trim the arches and have more lift but i would prefer the other way myself, as it keeps the weight lower down Quote Link to comment Share on other sites More sharing options...
stuck Posted March 2, 2009 Share Posted March 2, 2009 I'm running 35's with a three inch suspension lift, chopped arches and + 75mm arches. Dosen't catch due to axle articulation but rubs a bit on full lock (easy fix, just haven't got around to it yet ) Mick. Quote Link to comment Share on other sites More sharing options...
clbarclay Posted March 3, 2009 Share Posted March 3, 2009 The body on the RRC is pretty much the same as the discovery, the main differance is the shape of the outer skin of the wheel arch at the rear of the rear wheels. The RRC pannel is more angled as standard where as the discovery pannel curves round more. As a result manu discooverys have had a 'cammal cut' which makes them more like the RRC pannels. Basically in the case of 35" tyres, fitting a RRC will be much the same as your other thread about fitting them to a disco. Quote Link to comment Share on other sites More sharing options...
kmm Posted May 4, 2009 Share Posted May 4, 2009 Here is my wife's with 35" and 4" lift. Going to change to a 3" lift as i have springs sitting there. Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted May 4, 2009 Share Posted May 4, 2009 Simple, 70mm spring lift and 50mm arches. Done All you need is to work out the correct backspacing on your wheels and they will go on a treat Quote Link to comment Share on other sites More sharing options...
