Les Henson Posted February 22, 2006 Share Posted February 22, 2006 While working on this vehicle today I noticed engine oil was being sucked (or blown) into the inlet manifold. As the engine has on 94,000 miles on the clock, this seems a bit excessive. Does this engine have any known breathing problems? Looks like oil is coming out of the rocker cover gasket too. The top of the engine and down the drivers side it's oily. Any experience or comments please? Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 22, 2006 Share Posted February 22, 2006 Not usually a problem on 300s IMHO. It does look excessive on that though! Quote Link to comment Share on other sites More sharing options...
jjojjas Posted February 22, 2006 Share Posted February 22, 2006 my 200tdi with 160,000 looks the same. I clean it once in a while. I *think* its due to worn turbo on mine? Theres an o ring on the driverside rocker cover of the 200 that leaks, I have not worked on a 300 though so I don't know if you have one? Jas Quote Link to comment Share on other sites More sharing options...
white90 Posted February 22, 2006 Share Posted February 22, 2006 Mine did that although that doesn't look too excessive mine was worn bearing housing on the turbo, it made it smoke badly on overrun when descending from 8000mts in the Pyrenees. Turbo was rebuilt, that sorted it, Quote Link to comment Share on other sites More sharing options...
