Muddylandy Posted March 2, 2009 Share Posted March 2, 2009 Hi Guys A quick question, I took my truck out today upon return I noticed diesel dripping from the rear at an alarming rate. When you look at the tank from behind it appears to be coming from both sides along the guard/bracket. Is there a common fault i should look for or are the tanks known for failure? The tank appears sound and has never had any damp patches or the like nor has it been clouted or abused(recently) Thanks in advance, Regards Mark Quote Link to comment Share on other sites More sharing options...
western Posted March 2, 2009 Share Posted March 2, 2009 the tank has a stoneguard under it, sometimes these are spot welded on or just held by the same bolts that secure the tank to the chassis, any moisture in between the tank & guard will cause corrosion & you've found the result, definitly time to drain & drop the tank & see what's going on, reckon you will need a new tank. Quote Link to comment Share on other sites More sharing options...
Adi Posted March 3, 2009 Share Posted March 3, 2009 I know its does'nt match the symptom you see, but just to be sure,also have a look at the gasket, of the "fuel outlet cum level gauge" system is not holding up, the diesel sneaks along the side of the tank towards the front, accumulate and then drips at a considerable rate. This was the problem with the tank on my 110, with diesel dripping. Do tell us what was the problem when you find it. Cheers Quote Link to comment Share on other sites More sharing options...
