defender dinky Posted March 3, 2009 Share Posted March 3, 2009 hi, back now from ten days in the sun ,like to thank everyone for there replys to my steering wobble problem, not yet sorted someone been and had a test drive steering box knackered, Now a question, read some post today informing me i could use a axle from a disco 89/94 with disc's swap with my defender 90 straight swap, is this correct, also would i beable to use the steering box off the same car, my box is 6 bolt if it's a 4 bolt would my terminals still fit. thanks wayne. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 3, 2009 Share Posted March 3, 2009 Ref axle yes, you may need the pinion flange from your defender if the Disco one has the rubber doughnut. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 3, 2009 Author Share Posted March 3, 2009 Ref axle yes,you may need the pinion flange from your defender if the Disco one has the rubber doughnut. cheer's tony Quote Link to comment Share on other sites More sharing options...
KKMobile Posted March 3, 2009 Share Posted March 3, 2009 hi, back now from ten days in the sun ,like to thank everyone for there replys to my steering wobble problem, not yet sorted someone been and had a test drive steering box knackered, Now a question, read some post today informing me i could use a axle from a disco 89/94 with disc's swap with my defender 90 straight swap, is this correct, also would i beable to use the steering box off the same car, my box is 6 bolt if it's a 4 bolt would my terminals still fit. thanks wayne. I got myself a 200 tdi 90 last year as an upgrade to the Dicovery series 1 i had. i done the rear axle swap as the 90 had drum brakes. the axles swapped straight over with no issues. think it's the 300tdi Disco that has the dohnut?? but not the 200 or series 1 witchever you want to call em. The only thing you will have to do is turn the "Y" block main feed for the brake pipes round as the 90's come from the opposite direction. I changed the A frame as well while i was there as well. Hope this helps Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 4, 2009 Author Share Posted March 4, 2009 I got myself a 200 tdi 90 last year as an upgrade to the Dicovery series 1 i had. i done the rear axle swap as the 90 had drum brakes. the axles swapped straight over with no issues. think it's the 300tdi Disco that has the dohnut?? but not the 200 or series 1 witchever you want to call em.The only thing you will have to do is turn the "Y" block main feed for the brake pipes round as the 90's come from the opposite direction. I changed the A frame as well while i was there as well. Hope this helps hi, thanks for your reply very helpful, being a novice what's the A frame, and pleased to inform everyone who helped steering wobble fixed, thanks for all your help. wayne Quote Link to comment Share on other sites More sharing options...
white90 Posted March 4, 2009 Share Posted March 4, 2009 Just pop you head under the rear you'll see it two large cast arms from the chassis to the ball joint ontop on the diff casing. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 4, 2009 Author Share Posted March 4, 2009 Just pop you head under the rear you'll see ittwo large cast arms from the chassis to the ball joint ontop on the diff casing. thanks, learn some thing everyday Quote Link to comment Share on other sites More sharing options...
