DerbyDunky Posted March 3, 2009 Share Posted March 3, 2009 I have just got a 55 plate freelander td4 with reverse park sensors. However nothing happens when I am reversing. The red light on the switch on the dash flashes and theres a faint whirring noise at the rear but no bleeps. Could the bleeper be broken? Where in the vehicle is it located? Thanks in advance. Duncan Quote Link to comment Share on other sites More sharing options...
MJIbex Posted March 5, 2009 Share Posted March 5, 2009 If the light is flashing on any LR factory fit parking sensor switch then the ECU has detected a fault with the system; most likely to be a wiring/connector fault, if not then a sensor or worse an ECU itself fault. The light will come on continously if the system is opertaing correctly. So I would not think it is the beeper itself. Mark. Quote Link to comment Share on other sites More sharing options...
