landydave Posted March 3, 2009 Share Posted March 3, 2009 What are the issues with sticking 18" alloys on a Defender? (Apart from taste issues...) 1) Will they just fit on or will some sort of spacer/adaptor be needed? 2) I'm assuming the speedo would then be innaccurate? anyone done this? Dave Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 3, 2009 Share Posted March 3, 2009 It depends what you're trying to achieve and what they're from. 1) If they have the right hole placement (PCD) and offset they will fit, otherwise adaptors would be needed. 2) The accuracy of the speedo would depend on the tyre profile, so long as the outer diameter of the tyre is similar to the standard ones it won't be affected. Quote Link to comment Share on other sites More sharing options...
scatt Posted March 3, 2009 Share Posted March 3, 2009 As far as i know you will need hub adaptors, im guessing your thinking D2/ p38 alloys. they are an aquired flavour but ive seen 18" hurricanes on a defender with 35" mud tyres on. WELL COOL!! Quote Link to comment Share on other sites More sharing options...
Prith Posted March 4, 2009 Share Posted March 4, 2009 As far as i know you will need hub adaptors, im guessing your thinking D2/ p38 alloys. they are an aquired flavour but ive seen 18" hurricanes on a defender with 35" mud tyres on. WELL COOL!! Guys whats the PCD on a defender 110? Quote Link to comment Share on other sites More sharing options...
TJ101 Posted March 4, 2009 Share Posted March 4, 2009 What are the issues with sticking 18" alloys on a Defender? (Apart from taste issues...)Dave Are you sure Dave ??? You will need a set of adaptors,, about £350 ish from memory ?? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 4, 2009 Share Posted March 4, 2009 Guys whats the PCD on a defender 110? Google: Land Rover Defender PCD Google says 5 x 6.5" (5 x 165mm). Quote Link to comment Share on other sites More sharing options...
landydave Posted March 4, 2009 Author Share Posted March 4, 2009 Are you sure Dave ???You will need a set of adaptors,, about £350 ish from memory ?? Oh i doubt it, just wondering as i saw one advertised and didn't think you could do it... The adaptor cost alone rules out that sort of cosmetic change. Going for some chunkier tyres though.. Quote Link to comment Share on other sites More sharing options...
