bluespanner Posted March 3, 2009 Share Posted March 3, 2009 Look here Looks an interesting mod, and that turbo looks quite big! I wonder how the blower likes having to draw a petrolly mist. Anyone seen one of these before? Roland Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted March 3, 2009 Share Posted March 3, 2009 Someone i used to know had a 2.25 turbo SWB using Ren5GTT parts........used to smoke the tyres in third Quote Link to comment Share on other sites More sharing options...
Diff Posted March 3, 2009 Share Posted March 3, 2009 Look hereLooks an interesting mod, and that turbo looks quite big! I wonder how the blower likes having to draw a petrolly mist. Anyone seen one of these before? Roland A very heath robinson set up! Looks awful! and the turbo looks way too big. But the method is sound. It is an 'Old Style' draw through arrangement. You can only run limited boost (or combustion temps will be too high) as you can't use an intercooler. The advantage is that the carb and fuel pump don't need to be boost referenced as they work in the normal way. There is a slight efficiency loss compared to a well set up 'modern' blow through arrangement with intercooler. The reason for the white smoke as stated in the ebay ad is because in a draw through set up, the turbo needs a carbon seal arrangement on the compressor spindle, otherwise the oil lubricating the spindle is drawn into the intake. Regards, Diff Quote Link to comment Share on other sites More sharing options...
bluespanner Posted March 3, 2009 Author Share Posted March 3, 2009 Wouldnt the oil be drawn into the intake on conventional turbo setups anyway? How does the draw through method make it any worse? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 3, 2009 Share Posted March 3, 2009 Wouldnt the oil be drawn into the intake on conventional turbo setups anyway? How does the draw through method make it any worse? Maybe because you limit the amount of flow into the intake when you close the throttle-blade on the carb? Usually you don't have this on a TD. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted March 3, 2009 Author Share Posted March 3, 2009 Which would then draw a vaccuum inside the turbo, sucking the oil out. I get it. Quote Link to comment Share on other sites More sharing options...
andyb Posted March 4, 2009 Share Posted March 4, 2009 In Poole! Not to far from me. I'm tempted to go take a look Quote Link to comment Share on other sites More sharing options...
