Jason2 Posted May 8, 2009 Author Share Posted May 8, 2009 You have to cover up the hole otherwise you get covered in oil! Vac pump orf and .........................................................tap,tap,tap............ ....... Looks like it's Head off time, little end bearing? Broken valve? but it's not going to happen as I aint got the time or space at the moment. What do 200 tdi engines go for in England? Would a 300tdi be a straight swop? Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 8, 2009 Share Posted May 8, 2009 A complete Discovery engine would cost about £300. You could then transfer all your ancilliaries onto it. The trouble is, without pulling the head off, you don't know what you're gettting. I'd suspect it was a valve problem, listening to that clip. Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2009 Share Posted May 8, 2009 have you checked all the valve head shims are all in place ? missing ones just make the valve gap bigger & can fall into the sump/cam follower/push rod hole Quote Link to comment Share on other sites More sharing options...
Jason2 Posted May 8, 2009 Author Share Posted May 8, 2009 have you checked all the valve head shims are all in place ? Yeh! twice Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2009 Share Posted May 8, 2009 Yeh! twice least you know it's not those, must be inside the engine then, if the checks so far haven't found anything. Quote Link to comment Share on other sites More sharing options...
ian_s Posted May 8, 2009 Share Posted May 8, 2009 my 200tdi has a similar tap, nowhere near as bad though, and i think its down to excessive crankshaft endfloat. try getting a good grip on the crank pulley and push it back and forth in the engine, see if you can feel any movement. Quote Link to comment Share on other sites More sharing options...
CURLY Posted June 9, 2009 Share Posted June 9, 2009 Hi there, did you ever find out what the tappy tap tap tap noise was? Curly Quote Link to comment Share on other sites More sharing options...
Jason2 Posted June 9, 2009 Author Share Posted June 9, 2009 Hi there,did you ever find out what the tappy tap tap tap noise was? Curly Nah! Dam thing needed to much work doing to it (doors,chassis,bulk head) so I sold it on for spares. New owner promised to let me know if he manages to find out what the tapping is. Quote Link to comment Share on other sites More sharing options...
CURLY Posted June 9, 2009 Share Posted June 9, 2009 Nah! Dam thing needed to much work doing to it (doors,chassis,bulk head) so I sold it on for spares. New owner promised to let me know if he manages to find out what the tapping is. he he fair doo's! let us know if you do though!! cheers, CURLY Quote Link to comment Share on other sites More sharing options...
