nige90 Posted March 4, 2009 Share Posted March 4, 2009 Helping a friend trace a small coolant leak on a 2001 TD4. Seems to be coming from the oil cooler assembly behind the alternator and above the aircon compressor and looks a right pain in the ar*e to remove. From the little I can see there is only one coolant pipe so I assume there is a coolant feed (or return) directly into the block and hance a failed gasket. There also must be a couple of oil seals. So the big question is...is it a PITA or simply drop the aircon pump onto a stand, remove alt and voila..... Quote Link to comment Share on other sites More sharing options...
nige90 Posted March 4, 2009 Author Share Posted March 4, 2009 Someone must know, suerely Quote Link to comment Share on other sites More sharing options...
