BigMac1 Posted March 5, 2009 Share Posted March 5, 2009 I want to paint my ally chequer plate. At the minute its plain, but i'd like it black. Whats the best way to 'key' it for paint, and would I be alright with a normal spray can? Cheers Mick Quote Link to comment Share on other sites More sharing options...
stuck Posted March 5, 2009 Share Posted March 5, 2009 I think you would have to use a self etching primer first. I hope somebody sensible will be along soon to confirm or deny that! Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted March 5, 2009 Share Posted March 5, 2009 yes you need to put 1 coat of etch primer on first then top coat on to that, you can buy etch in spray tins although it isnt cheap. make sure you top coat is compatible with the etch else you will be peeling it all back off!! good luck Quote Link to comment Share on other sites More sharing options...
paintman Posted March 5, 2009 Share Posted March 5, 2009 U-Pol do an aerosol etch primer called Acid#8. On ebay if you can't find it anywhere else. http://www.u-pol.com/countries/en/downloads/tds/acid8.pdf Quote Link to comment Share on other sites More sharing options...
smo Posted March 6, 2009 Share Posted March 6, 2009 Definately use acid etch otherwise as said its a non starter, you might find using a scotchbrite pad will also help to key the surface before this for extra bonding. Quote Link to comment Share on other sites More sharing options...
wozza35 Posted March 6, 2009 Share Posted March 6, 2009 I used Hammerite special metals primer and then plasticote satin black over the top and it turned out well Quote Link to comment Share on other sites More sharing options...
tel Posted March 6, 2009 Share Posted March 6, 2009 I used Hammerite special metals primer and then plasticote satin black over the top and it turned out well ive tryed all they other ways of painting it and this way was the only way that worked for me as the jet wash still peeled all the paint off with etching primer no matter what i did Quote Link to comment Share on other sites More sharing options...
BigMac1 Posted March 6, 2009 Author Share Posted March 6, 2009 I used Hammerite special metals primer and then plasticote satin black over the top and it turned out well ive tryed all they other ways of painting it and this way was the only way that worked for me as the jet wash still peeled all the paint off with etching primer no matter what i did I think I'll go this route, as mine gets high pressure washed after every outing. Also I've used plasticote a few times and its brilliant paint. Cheers for all the input, Mick Quote Link to comment Share on other sites More sharing options...
HoggyN Posted March 7, 2009 Share Posted March 7, 2009 I think I'll go this route, as mine gets high pressure washed after every outing. Also I've used plasticote a few times and its brilliant paint.Cheers for all the input, Mick If you want a bombproof finish then anodising would be the way to go. You can do it yourself - although after reading this link I think I probably wouldn't bother! Quote Link to comment Share on other sites More sharing options...
paintman Posted March 7, 2009 Share Posted March 7, 2009 ive tryed all they other ways of painting it and this way was the only way that worked for me as the jet wash still peeled all the paint off with etching primer no matter what i did Great way of removing paint. Lots of business from car owners using pressure washers at zero inches from the paintwork suddenly finding that a stone chip has allowed the jet to rip a big chunk of lacquer off. If its taking paint off its TOO CLOSE. About a meter (yard for us oldies) on paintwork is close enough. Quote Link to comment Share on other sites More sharing options...
