235.85.16 MT tyres Khumo, cooper ?
T1G UP
Try giving 4site4x4 a ring on 08701129407 - this is the technical advice number, but they will give you the number of your local stockist. They stock Kumho KL71's. When you ring the second number they will give you a fitted price, but you can ask for a price without fitting and collect them if you want.
I should let you know that I shopped around on Tuesday and these were unavilable with no answer on when they will be in stock. They are a REALLY chunky tyre also, they look huge. Average price was £71 for the Kumho, £91 for the STT (235/70R16).
Some Kumho's have been in short supply in the UK over the last couple of months as I have been trying to get some from the importer to send here, but there is new stock coming in around about now so if you don't get anything try again in a couple of weeks.
Marcus,
Having used both on our site vehicles go for the Coopers, I found the Kumo's never had enough grip with the side lugs when climbing out of ruts, even when the ground was dry. I found the Coopers were almost on a par with BFG muds either on or off road.
Brookers
