Fuel warning light
Naks
 Share
Hi all
Being a n00b Disco2 Td5 owner, how far can I go when the fuel light comes on?
I also notice that it comes on above the red line unlike other cars? :huh:
Hi all
Hi you are normally looking at 1-2 gallons, but obviously letting it run really low there is more chance of picking up any carp off the bottom of your tank which your pump wont like.
Also if you are driving off road at odd angles there is a chance the pump won't pick it up properly especially at steep side slopes.
firemannotsam.
thanks, after much searching, I found it in the manual - 9L when the light comes on.
Btw - gallons? No one told you Brits that this is the 21st century? :P
You're driving a Land Rover, Land Rovers are calibrated to use gallons not liters. Using liters rather than gallons can damage your fuel pump that's why countries that don't use real gallons always seem to think Land Rovers are unreliable.
Wheelbases are measured in inches, fuel is measured in gallons and if you do otherwise the Land Rover gods WILL smite you down.
...that's why countries that don't use real gallons always seem to think Land Rovers are unreliable.
no, that's because countries that don't use gallons actually have real off-roading. Greenlaning is what grannies in wheelchairs do around here ;)
 Share
