jonathan day Posted February 23, 2006 Share Posted February 23, 2006 did you know you can drastically improve the turning circle of your late disco2,if you fit early disco 2 lockstops,you must have 16inch wheels,it only takes 5 mins with a 17mm socket Quote Link to comment Share on other sites More sharing options...
Aston Posted February 25, 2006 Share Posted February 25, 2006 There is a service bulletin from Land rover to all Dealers stating that the 29mm streering lock stops can be changed for 23mm stops, thus improving the turning circle 9 inches for every mm taken off the stops. The change can be done FOC by your dealer or you can buy the stops for approx £3.50. Technical Bulletin 0026 CDS …. ref L8867bu …. & the 23mm lock stops. (manovering in tight spaces) Cheers Aston Quote Link to comment Share on other sites More sharing options...
LR90 Posted February 25, 2006 Share Posted February 25, 2006 Given the turning circle (kerb to kerb) is a standard comparitor for cars you have to wonder why they went for the larger stops in the first place. Also for those of us with larger wheels, wonder if the 29mm stops could be a better starting point than heavily screwed out 23s. Anyone tried this? Quote Link to comment Share on other sites More sharing options...
geoffg Posted February 25, 2006 Share Posted February 25, 2006 Hi I have a "51" disco 2 do you know what stops it will have fitted Geoff Quote Link to comment Share on other sites More sharing options...
Aston Posted February 27, 2006 Share Posted February 27, 2006 Given the turning circle (kerb to kerb) is a standard comparitor for cars you have to wonder why they went for the larger stops in the first place. Also for those of us with larger wheels, wonder if the 29mm stops could be a better starting point than heavily screwed out 23s. Anyone tried this? The longer stops were installed because if you remember when you purchased your Disco 18" wheels were offered as an option. If the longer lock stops weren't installed the 18' wheels would scrub the chassis. Cheers aston Quote Link to comment Share on other sites More sharing options...
LR90 Posted February 27, 2006 Share Posted February 27, 2006 The longer stops were installed because if you remember when you purchased your Disco 18" wheels were offered as an option. If the longer lock stops weren't installed the 18' wheels would scrub the chassis. Cheers aston There were no options when I bought my Disco but I see what you mean Ta Quote Link to comment Share on other sites More sharing options...
rormck Posted January 24, 2008 Share Posted January 24, 2008 Hi Tried landrover to get part numbers for shorter style lock stops , but i am unable to get a part number from them ..HELP..anybody know?..Thanks Quote Link to comment Share on other sites More sharing options...
cipx2 Posted January 24, 2008 Share Posted January 24, 2008 Part # is FTC5151 for the short ones (2 pcs required) I think you can shorten the existing ones (careful with the thread). Or take out a lock stop and go to your local nuts&bolts shop and they'll help you find a 25 mm long one which you can shorten a bit. Quote Link to comment Share on other sites More sharing options...
rormck Posted January 28, 2008 Share Posted January 28, 2008 Thats great..many thanks..Roy Quote Link to comment Share on other sites More sharing options...
lynall Posted January 29, 2008 Share Posted January 29, 2008 Looked at mine last night and they are the 23mm ones with two washers under each one, for the 18" wheels, so i removed the stops and the washers and refiited the stop and it only touched very slightly on full lock one side, so i refitted one washer to each side which has done the trick, but i will have to keep a look out for thinner washers. The thread is about 20mm long so plenty to play with. Lynall Quote Link to comment Share on other sites More sharing options...
