stevegibbs Posted March 7, 2009 Share Posted March 7, 2009 Hi, can a 200tdi engine be put in place of a 3.9 engine on an autobox Quote Link to comment Share on other sites More sharing options...
cipx2 Posted March 7, 2009 Share Posted March 7, 2009 Have a look here: http://forums.lr4x4.com/index.php?showtopic=23193 Quote Link to comment Share on other sites More sharing options...
stevegibbs Posted March 16, 2009 Author Share Posted March 16, 2009 Hi, i'am still tring to find out what would be required to put a 200 tdi engine in place of a 3,9 v8 on an autobox. The 200 came out of a 5 speed so would need the flywheel replacing for a flex platebut i am thinking that the 200/300 tdi should fit the gearbox unless a different bell housing is used for the v8. Kick down cable and brackets to fit the tdi fuel pump, exhaust, change engine fixings. I have both Disco's so have must of the bits. If anyone can help please do. Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 16, 2009 Share Posted March 16, 2009 Really you need the autobox out of a 200TDI auto Disco/Rangey, they have different change points to the V8 box, the component parts you have wouldn't make a good marriage. But then I suppose if you'd read the linked post you would know that anyways... Quote Link to comment Share on other sites More sharing options...
neb Posted June 28, 2010 Share Posted June 28, 2010 are the different ratios too far out to be usable? Currently have a 200tdi with a manual gearbox but lost a few gears over the weekend, the trucks only used offroad. I already have a autobox out of a 94 3.9 v8 so was wondering if it could get me out of trouble for the time being? Seeing as it stays in low i would imagine it would be okay Quote Link to comment Share on other sites More sharing options...
