daven2695 Posted March 7, 2009 Share Posted March 7, 2009 Hi all Having a problem with the rear windows not working on my 96 Disco 1 ES V8, the front are fine has anyone had similar problems or got any idea where to start? cheers Dave Quote Link to comment Share on other sites More sharing options...
PEASEY Posted March 7, 2009 Share Posted March 7, 2009 It will be the window lift ecu under the glove box,IIRC,its the top "black box" bolted to the side of the car where the passengers feet go.Remove the circuit board and look at the soldered blobs you will see one thats dry(cracked and just ropey looking)re solder that puppy and your rear windows will be well again.Be careful not to drop anything on the second black box down as this is the crash sensor and your indicators will flash constantly until its reset(dont ask me how I know) a real easy fix that should only take about ten minuites once you have located the board. Quote Link to comment Share on other sites More sharing options...
karlo Posted March 7, 2009 Share Posted March 7, 2009 It will be the window lift ecu under the glove box,IIRC,its the top "black box" bolted to the side of the car where the passengers feet go.Remove the circuit board and look at the soldered blobs you will see one thats dry(cracked and just ropey looking)re solder that puppy and your rear windows will be well again.Be careful not to drop anything on the second black box down as this is the crash sensor and your indicators will flash constantly until its reset(dont ask me how I know) a real easy fix that should only take about ten minuites once you have located the board. Have a look here Rear Window Fix Quote Link to comment Share on other sites More sharing options...
