titan Posted March 7, 2009 Share Posted March 7, 2009 im in the middle of stripping my 90 for a rear build and a bit dose of tlc and i need to take of the rear tub or at leased lift the floor up but im not sure of the best way to do it i have searched for previous thread which im sure there is but cant find any cheers shane Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted March 7, 2009 Share Posted March 7, 2009 The floor CAN be removed... however you will find that it is attached rather well...many many spot welds (alarmingly difficult to spot...) and many many rivets (made of some of the hardest steel known to man!!!) Far easier to remove the whole tub- bolts along the top of the rear crossmember, along the top edge and ends of the seatbox, plus a couple of brackets underneath (depending on body type)- oh and you will have to disconnect the electrics... Quote Link to comment Share on other sites More sharing options...
titan Posted March 7, 2009 Author Share Posted March 7, 2009 The floor CAN be removed... however you will find that it is attached rather well...many many spot welds (alarmingly difficult to spot...) and many many rivets (made of some of the hardest steel known to man!!!)Far easier to remove the whole tub- bolts along the top of the rear crossmember, along the top edge and ends of the seatbox, plus a couple of brackets underneath (depending on body type)- oh and you will have to disconnect the electrics... sound good to me the floor has a few holes init and the supports looked tatty but if i can get he hole tub off i can have a better look thanks think the hole thing will be off tomorro Quote Link to comment Share on other sites More sharing options...
