onelife33 Posted March 8, 2009 Share Posted March 8, 2009 Few weeks ago started disco and moved it a few feet of on street. Next day came to use it and would not start, engine cranks but does not fire. Have checked and there is a spark and fuel in cylinders. Have replaced Spark Plugs, HT leads, dizzy arm, ignition coil and amp but now run out of ideas need to sort it soon. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted March 9, 2009 Share Posted March 9, 2009 Go to the "Manuals" section in the tech archive index thread and run through the appropriate diagnostics manual posted there. Quote Link to comment Share on other sites More sharing options...
kevinr Posted March 9, 2009 Share Posted March 9, 2009 if there is spark and fuel, then it should go. Are you positive there is fuel? I had a very similar problem a while back, the initial problem was the amp, but the mechanic from the motoring association that checked things out for me, reconnected the wiring on the side of the coil all wrong, so the ECU was not getting a correct signal, and not firing the injectors. Quote Link to comment Share on other sites More sharing options...
