cholo Posted March 11, 2009 Share Posted March 11, 2009 Any advice appreciated guys , just got my defender 90 tdi 1989 , i expected some work would need done over the coming months but after a few days its hit me had it running monday morning all was fine went to turn it over tuesday morning -nothing ( red lights on dash came on for a second , a slight clicking noise then nothing ) i had a brand new battery so fitted that in but the exact same.. Could this be the starter or solenoid or maybe even the alternator thats causing this ? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 11, 2009 Share Posted March 11, 2009 Check you have a good clean earth connection first. If necessary - use a jump lead from the earth terminal on the battery directly to the starter body. Les. Quote Link to comment Share on other sites More sharing options...
cholo Posted March 11, 2009 Author Share Posted March 11, 2009 Les please excuse my ignorance but what am i looking for when i do this ? do i have the ignition switched on ? Quote Link to comment Share on other sites More sharing options...
fender1234 Posted March 11, 2009 Share Posted March 11, 2009 you put the jump lead between the battery negative and starter motor body and then see if the starter woks, if it does then that means its a bad earth if it doesnt then the problem lies somwhere else. Quote Link to comment Share on other sites More sharing options...
cholo Posted March 13, 2009 Author Share Posted March 13, 2009 Ok guys i put the jumplead on the starter motor body from battery , still nothing , so any ideas what to look for now ? Quote Link to comment Share on other sites More sharing options...
markyboy Posted March 13, 2009 Share Posted March 13, 2009 Ok guys i put the jumplead on the starter motor body from battery , still nothing , so any ideas what to look for now ? Check that the +ve lead is tight on both the battery and the starter motor. It's the thick red lead on the starter, 13mm spanner on the starter and 1/4 whitworth on the battery. Take care not to short the leads out to earth with your spanner, best remove the -ve battery lead to be safe. If these are tight and in good condition it's beginning to look like the starter is at fault. It sounds like the solenoid is going in but not activating the starter. Does it just click the once or does it keep clicking for as long as the key is held in the start position? If it clicks just the once it looks like the starter, several clicks indicates low voltage. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted March 13, 2009 Share Posted March 13, 2009 You could try starting with a jump pack to rule out whether its the battery or not. Also if you switch the headlights on whilst trying to start, if the headlights dim then its not a bad connection if the stay the same then there is probably a bad connection somewhere. Quote Link to comment Share on other sites More sharing options...
cholo Posted March 13, 2009 Author Share Posted March 13, 2009 Guy it was the wires at the starter , they were lose , a quick tighten and first turn of the key and we were started , thanks for the info though guys , much appreciated.. Quote Link to comment Share on other sites More sharing options...
