BLACKJACKS Posted March 13, 2009 Share Posted March 13, 2009 sorry if this has been asked before i have an oil leak coiming from a bolt hole in back of gear box ive been told its where the breather kit goes to . its getting bad now as im new to this defender stuff need someones help on this its sort of rear of drain bolt hope some one can help Quote Link to comment Share on other sites More sharing options...
Grant. Posted March 13, 2009 Share Posted March 13, 2009 What engine have you got? Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 13, 2009 Share Posted March 13, 2009 ...... this defender stuff ..... Define "Defender".... Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2009 Share Posted March 13, 2009 which model of Defender/engine/gearbox ? Quote Link to comment Share on other sites More sharing options...
BLACKJACKS Posted March 13, 2009 Author Share Posted March 13, 2009 oh sorry dum me i have a 300tdi 110 1995 Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2009 Share Posted March 13, 2009 so a R380 main gearbox, if you can add a photo that would help us give correct advice. Quote Link to comment Share on other sites More sharing options...
BLACKJACKS Posted March 13, 2009 Author Share Posted March 13, 2009 ill do a pic up tomorrow have to get under landy this is my 1st landy and trying to work out whats what so thanks for the help Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2009 Share Posted March 13, 2009 main gearbox breather pipe/banjo bolt is fitted to the right hand side & transferbox breather pipe/banjo bolt is fitted to the top of the casing. Quote Link to comment Share on other sites More sharing options...
BLACKJACKS Posted March 13, 2009 Author Share Posted March 13, 2009 m8 you have said it in the post about oil leak its coming out of the bel housing drain plug?which is behind the drain bolt does this help and i under stand its a big job . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 13, 2009 Share Posted March 13, 2009 May I first of all say welcome along, and welcome to Defender ownership. It's almost as good as Series ownership. Putting my grumpy hat on for a brief moment, if you could try writing in coherent sentences and not using 50% TXT SPK then we might be able to grasp what the greasy poop you're on about and offer a bit more help if you're struggling to explain what the oily thingy next to the rusty bit is then get your camera under there and post a picture, it saves a lot of time in the long run. Anyways, on to business. If you have a random threaded hole near the top at the back of your gearbox it's quite likely the breather especially if the thread is 1/8" BSP. That should have a banjo bolt and a couple of feet of pipe on it to vent to air but to keep it above water. If it's not there then now is as good a time as any to nip to your local HypHose and buy a handful of 1/8" BSP stainless 90 degree swivel elbows that accept 6mm push-fit nylon hose, and a 10m reel of hose in the colour of your choice to go with, and a pack of 100 cable ties. You can then screw a fitting into the hole, as well as the one on the transfer box and each of your axles (and possibly the engine too but I don't do diseasals) and then run a load of hose from the fitting up as high as possible. Congratulations, you now have raised breathers all round. Bling bling! (Also are you definitely on about the gearbox and not the transfer box?) Quote Link to comment Share on other sites More sharing options...
