mike4444244 Posted March 22, 2009 Share Posted March 22, 2009 Hi done a search as I'm sure this must have been covered but I cant find anything, I'm having a nightmare trying to adjust the throttle linkage on my series 3 2.25p (zenith carb) so was thinking about converting to a cable throttle rather than the rods and levers one. Has anyone done this and is there a relatively easy bolt on set of parts to use, I was thinking defender pedal assembley and make a bracket to fit the carb? Ta Mike Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted March 22, 2009 Share Posted March 22, 2009 Hidone a search as I'm sure this must have been covered but I cant find anything, I'm having a nightmare trying to adjust the throttle linkage on my series 3 2.25p (zenith carb) so was thinking about converting to a cable throttle rather than the rods and levers one. Has anyone done this and is there a relatively easy bolt on set of parts to use, I was thinking defender pedal assembley and make a bracket to fit the carb? Ta Mike Quite an easy job.... I make up one off throotle cables for kit / rally / track cars on an almost daily basis and even for a super, all singing all dancing one with bearings either end should the cable need to pull slightly off share they are only about £30 for one about 1 netre long. I suggest you use one with locknut bulkjeads either end of the outer cable so you can fasten it through the footwell. Then have a clevis onto a little tab welded to the pedal ( or use a Defender pedal ) and a direct replacement ball joint thing to go onto the carb linkage. All you will have to make is a liyyle bracket to fasten the carb end of the outer cable to. I think I am making this sound more complicated than it actually is. Give me a call if you need a cable making up with proper swaged on bulkheads and the appropriate ends Many thanks David Quote Link to comment Share on other sites More sharing options...
tacr2man Posted March 22, 2009 Share Posted March 22, 2009 You can leave all the series linkage in place, and just make a bracket to act as anchorage for outer cable on bulkhead , and link cable to bell crank suitably positioned . I used V8 cable when I put V8 in 88, and same with 3.8 diesel in 109 . Not a difficult task at all . I cant understand you having a prob with adj series linkage as its very versatile with all the adj points . or is it you are trying to reverse action at carb after fitting different type of carb . ? Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted March 22, 2009 Author Share Posted March 22, 2009 Hi Thanks for that, I like the idea of using the first bit of the linkage and putting a bracket on the footwell, its a bit fiddly/tight on space after that as I have a coilpack and an edis unit in the way B) Mike Quote Link to comment Share on other sites More sharing options...
