What steering column have i got ???
zim
Morning,
I'm busy trying to find a steering wheel for my toy, but i'm not sure which boss kit to get because i don't know which column i've used.
We've had numerous defenders / discos / range rovers in for breaking so a vast range of parts.
I was under the impression that it was from a defender, but the steering wheel we have managed to get fit is from a disco 200 (we think)....
Below are some pictures where you can kind of see it in the background, any ideas ?
this is the top, the wheel is just placed on. i've cut off the bracket that had the ignition barrel on
Thanks
Gordon
that steering wheel looks like one off an 90 110 to me
the steering wheel in the bottom picture is from a series, just placed on - doesn't fit.
it's the column i'm unsure about.
The steering wheel in the bottom image may well have been fitted on a series, but it's definately a 4 spoke wheel as fitted to early 90/110, so 36 spline.
The column you have looks to be from a Disco / RRC - the flange at the lower end is designed to bolt flat to the bulkhead footwell.
Matt
