zulublue Posted March 25, 2009 Share Posted March 25, 2009 I have just ordered a Gwyn Lewis wide angle prop for the front of the 90, is there a certain way this should go on, spline sleeve at the top or bottom, the props I have fitted before I have put the sleeve towards the bottom so to let water out if any gets in. Any other thoughts on this welcome. Quote Link to comment Share on other sites More sharing options...
western Posted March 26, 2009 Share Posted March 26, 2009 standard props should be fitted with the splined slider section at the transfer box end, I would fit these modded props the same. Quote Link to comment Share on other sites More sharing options...
gwyn lewis Posted March 26, 2009 Share Posted March 26, 2009 you fit them with the shorter part of the propshaft at the transfer box end,as this is the tallest part of the prop and wont let any water in them, the ends are plug welded on ours to help stop the water getting in and it also allows the grease to go down the splines and not out of the cap when you grease them GWYN LEWIS Quote Link to comment Share on other sites More sharing options...
zulublue Posted March 26, 2009 Author Share Posted March 26, 2009 Thanks Gwyn, look forward to the delivery. Quote Link to comment Share on other sites More sharing options...
