hattie Posted March 27, 2009 Share Posted March 27, 2009 Hope this might help some other poor puzzled owner at some point. I posted a question a while ago when I had a problem with the heater fan suddenly starting at high speed even when the switch was off. I could hear arcing and assumed at first that damp was getting at the back of the switch. I removed the radio to feel the back but it was quite dry so I took out the pollen filter so I could feel the matrix for any damp. Still all ok. After much head scratching and almost at the point of taking the car to a main dealer, I took the radio out again to try and see any visible wiring as the arcing sound seemed to come from there. At the back of the cavity a bunch of wires marked heater was tucked behind a steel tab with a hole which is a guide for a lug on the back of the radio. This tab has a sharp back edge, and over the 5 years since the wires were put there during manufacture, one had finally rubbed through the plastic and was shorting on the tab! Job done, but what would a main dealer have charged me?! Quote Link to comment Share on other sites More sharing options...
viorelluta Posted March 30, 2009 Share Posted March 30, 2009 Hope this might help some other poor puzzled owner at some point. I posted a question a while ago when I had a problem with the heater fan suddenly starting at high speed even when the switch was off. I could hear arcing and assumed at first that damp was getting at the back of the switch. I removed the radio to feel the back but it was quite dry so I took out the pollen filter so I could feel the matrix for any damp. Still all ok. After much head scratching and almost at the point of taking the car to a main dealer, I took the radio out again to try and see any visible wiring as the arcing sound seemed to come from there. At the back of the cavity a bunch of wires marked heater was tucked behind a steel tab with a hole which is a guide for a lug on the back of the radio. This tab has a sharp back edge, and over the 5 years since the wires were put there during manufacture, one had finally rubbed through the plastic and was shorting on the tab! Job done, but what would a main dealer have charged me?! if you were in Romania, probabily around 5,000 Euros (provided they could sove the issue before replacing AT LEAST: fan, heater matrix, air conditioning completely, most likely also the ECU... ) Quote Link to comment Share on other sites More sharing options...
