Bob RRC Posted March 27, 2009 Share Posted March 27, 2009 i heard about RRC cheap suspension lift: TLC 80 original front springs into the rear of RRC + RRC original rear springs with spacers into the front = about 3" lift i ask it cause of some problems whith terrafirma heavy load springs on RRC (at present time) - i have enough 3" lift, but its to tough -(( so im thinking about tlc 80 original front springs, both in front and rear of my RRC - as result we have 3" lift +softness + low budget does any body knows about compatibility of tlc 80 original front springs and RRC ??? Quote Link to comment Share on other sites More sharing options...
denski Posted March 27, 2009 Share Posted March 27, 2009 Hello! Try to ask this man: http://forums.lr4x4.com/index.php?showuser=1651 I know that he uses TLC springs in his Disco and has a rich photo album devoted to this topic. Quote Link to comment Share on other sites More sharing options...
Dikiy Posted March 30, 2009 Share Posted March 30, 2009 Hello neighbour! Yes, I tryed. Any questuions I'll answer. ProComp +4" all around On the front: Britpart HD Yellow Coil Springs - Rear 220lbs/inch DA4203 On the Rear: TJM TLC front springs XGS C/Load Front Coil Spring (70mm) for 80 Series (770FRHD80B) Description Part no: 770FRHD80B Approx 70mm (±3”) lift - Height: 515 - 525mm Wire MAT: 18 Suitable for: Constand Load Spring Rate: 240 lbs per square inch http://dikiy.io.ua/album194104 Quote Link to comment Share on other sites More sharing options...
