Fitting Cooling Vents to 90 / Defender / Challenge Front Wings
I have a similar post on here from a while ago when I had cooling probs on the V8
Fitting 2x Kenlowes did help hugely, but there is still the issue of getting the heat OUT
as much as blasting it in through the radiator. I fitted the 200/300 / TD5 vents ...one
to each wing and wow what a difference......
When I then fitted the new challenge wings I didn't bother, I wondered if I really needed them
answer soon showed up that yes - I did :(
So, today I redid the vents - as in plural, if one vent each side was good, then twin vents will be even
better, this is a quick how to guide.
Ist - decide on the orientation of the 2x vents, I had to take account of the cage down tubes ..
I have used one of each flavour and decided on this shape :
Then I made up a simple template, so I could always get a match on both the other side and an easy way should
I mash a wing and want to replace wing / vents etc. The template was then fitted and permaenant marker run around both side,
then the 8x corners were hole sawed out , and a jig saw then between the holes. Masking tape is good here
as sliding a jigsaw when cutting over a wing will often damage the paint surface, once cut remove masking tape :)
The vents are normally held in with horrible little plastic thin "Tangs" into plastic plugs - which often snap off, also for what I am doing here
they often don't sem to like to fit quite right, so here I cut off all the fixing studs and drilled them out with a 5,2mm drill
fitted to the wings, drilled through the ali wing where they are going, then redrilled those holes to take Rivnuts
then simply shoved domed allen bolts in to suit
When its up to temp and the fans kick in the amout of air movement is superb :)
Thought it may be of use to the V8 Boys :)
Nige
 Share
