Gilslandy Posted March 30, 2009 Share Posted March 30, 2009 hi guys!!! first of all well done for this forum!! i have a defender td5 and lately i put the double shock turrets on the front....i bought the turrets from paddock....my problem is that the outer shock is touching with coils! when on road, normal driving it almost touches, then when it starts to flex it touches!!! don t know y!!! if i put the shock the other way round that is the shaft with the axle and the 'case' with the turret...will it work properly?? thanks gil Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted April 1, 2009 Author Share Posted April 1, 2009 any help pls??? gil Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted April 1, 2009 Share Posted April 1, 2009 Sounds like some quality paddocks parts. Obviously they need to the 'fettled' a bit to move the shocks further away from the springs. But not too far, or the inside of the tyres will rub on them on full lock. Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted April 1, 2009 Author Share Posted April 1, 2009 thought so that it might be a 'damage' from paddock by any chance do the shocks work if i fit them the upside down??? thanks gil Quote Link to comment Share on other sites More sharing options...
David Wright Posted April 1, 2009 Share Posted April 1, 2009 Shock absorbers will work in either direction ( either the correct way up or upside down) but of course upside down the outer sleeve will fill with water unless there is a hole in the casing to allow drainage Quote Link to comment Share on other sites More sharing options...
Gilslandy Posted April 1, 2009 Author Share Posted April 1, 2009 thanks alot!! so even if they are gas shocks like the es9000's...they will work upside down. gil Quote Link to comment Share on other sites More sharing options...
