braided brake line
turbonutter
looking for the best place to get braided brake line
i want to make my own so can i buy it on a roll ?
my plan is to make lines that run down the chassis and then down the front hockey sticks
will need two down each side as im running twin lines to portal brakes
Dave llama llama hoses page
can supply hoses in any length with reusable fittings for you to fit yourself.
you can get a choice in plastic coated cover of various colours over the top of the braid if you want.
ill second that, Dave @ Llama sells braided brake lines at about £12 for up to a metre including ends and coloured sleeving but can do any size required and are normally delivered within 48 hrs
Nobby
I did that exactly. Dave made them up and sent them to me within a couple of days. Surprisingly not much more expensive than standard length braided.
kool , how long did u make the lines ?
have u any pics of your install ?
Only put them on at the weekend so still need to do a bit of fettling. 1.8 m long rings a bell, but I might be wrong.post-784-1238534865_thumb.jpg
Going to weld a clip to the axle case to stop chafing. Sorry about the springs.
similar clip here somewhere. Seems to be another blue pipe here too.
