Loss of drive
Hi there
Wondered if anyone can help
I changed the front output flange and oil seal on my transfer box (110 200tdi) yesterday to try and cure a persistant oil leak. I now have no drive, the transfer lever doesn't appear to select high or low but it will select diff lock. I've just taken the transmission tunnel off and diconnected the rod to force the selector into position but it has made no difference. I don't know if this has anything to do with it but the new output flange was slightly different. When I tightened it up with the original thin metal seal cover it locked soild so I had to loosen it off and omit the cover. The overall length of the flange is the same as the original though and it now turns freely
Cheers mark
 Share
