JST Posted August 19, 2005 Share Posted August 19, 2005 i have a copy then when you go to run it it comes up with this msg: 'microcat has not found an authorsied dongle' contact your microcat supplier' i tried my supplier but he didnt have any ideas anyone else any ideas what i need to do to make it run? i am running XP. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted August 19, 2005 Share Posted August 19, 2005 James, Try looking at the route directory of the disk and browse its contents there should be a text document and a "file" to copy and paste into a particular dirctory which will be indicated in the text doc ! Quote Link to comment Share on other sites More sharing options...
tuko Posted August 19, 2005 Share Posted August 19, 2005 1. You have to use an earlier version of microcat, that has a crack folder/file with it. 2. Then what you have to do is, with your up to date cd, copy over the "LRE_data" to the same directory thats installed in your computer ( usually in you C/ ), minus the "DSET" & "MCHELP32" files. 3. Start as usual, the files should be up to date, including any new vehicle information. This works for me and I'm running on XP Pro. Good luck. Todd. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 20, 2005 Share Posted August 20, 2005 strange that James others worked fine. you can borrow my copy to load if you want to collect it. Quote Link to comment Share on other sites More sharing options...
JST Posted August 21, 2005 Author Share Posted August 21, 2005 Les, many thanks its now working a treat, or will be once i get my head around how it all works!!! thank you for all the PMs as well, problem resolved. Quote Link to comment Share on other sites More sharing options...
western Posted August 21, 2005 Share Posted August 21, 2005 To run my Microcat, I have to reset the desktop clock [lower right corner] to Jan 5th 2005, it then runs and allows me to login and use it, you might have to do the same. Quote Link to comment Share on other sites More sharing options...
reedx Posted August 22, 2005 Share Posted August 22, 2005 B) Would someone be able to PM me details of where I could "find" a copy of this Microcat? I've got EPC (with 2002 update) but don't find it particularly good. Colin Quote Link to comment Share on other sites More sharing options...
