jimmy_neutron Posted April 1, 2009 Share Posted April 1, 2009 Is the cable between the alternator and starter (main charge cable) the same part number on a 90 200tdi without aircon (45A alternator) as the same cable on a 90 200tdi with aircon (65A alternator). Wanting a definate answer to "do i need to change the cable when fitting a 65A alternator". TA Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2009 Share Posted April 1, 2009 It's part of the engine harness & if your uprating the alternator all the main power cables from Alt to starter & battery need uprating to cope with the increased amperage. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted April 2, 2009 Author Share Posted April 2, 2009 It's part of the engine harness & if your uprating the alternator all the main power cables from Alt to starter & battery need uprating to cope with the increased amperage. Thanks western. I was hoping that just changing from the standard 45A to the standard 65A would meen that i could just leave the standard wiring but i suppose its nothing of a job to change it while i'm there. Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2009 Share Posted April 2, 2009 110 parts book shows different part numbers for the 200Tdi engine loom with a 45amp or 65amp alternator, so there must be a difference between the looms to need different part numbers, these are also common looms to the older 2.5TD engines the 65amp version is PRC6082 for TD & 200Tdi from November 1989 onwards. hth Quote Link to comment Share on other sites More sharing options...
