foggy3061 Posted April 1, 2009 Share Posted April 1, 2009 Part numbers for the following please (early 90): The two small bolts that fix thru the ball joint housing into its carrier. Think they are 5/16" (aren't metric as its an early vehicle). Seen here either side of the ball joint rubber boot. Quote Link to comment Share on other sites More sharing options...
zim Posted April 1, 2009 Share Posted April 1, 2009 on my microcat it gives two types - metric & imperial - M8 or 5/16 See the below picture and you will see the part numbers as well if you want to buy from a dealer. Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted April 1, 2009 Author Share Posted April 1, 2009 on my microcat it gives two types - metric & imperial - M8 or 5/16See the below picture and you will see the part numbers as well if you want to buy from a dealer. Excellent, thanks Zimsoundz. Quote Link to comment Share on other sites More sharing options...
zim Posted April 1, 2009 Share Posted April 1, 2009 no problem G Quote Link to comment Share on other sites More sharing options...
