foggy3061 Posted April 2, 2009 Share Posted April 2, 2009 Once again, help with the part numbers for the following please (for early 90): The 4 long bolts that hold the steering box (4 bolt steering box top if it makes any difference) to the chassis. The 2 tab washer plates for the 4 bolts mentioned above. Lastly, the 2 bolts and nuts seen here just above and either side of the drop arm (they hold the bracket from the panhard rod chassis bracket to the steering box). Thanks in advance for your help. Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2009 Share Posted April 6, 2009 everything you need on these parts diagram. check the notes at bottom of list to ensure you order the correct items Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted April 7, 2009 Author Share Posted April 7, 2009 everything you need on these parts diagram.check the notes at bottom of list to ensure you order the correct items Once again, thanks Western, spot on! Quote Link to comment Share on other sites More sharing options...
