NegevLandRover Posted April 2, 2009 Share Posted April 2, 2009 Been away for a while - well actually just in-active and/or lurking I did post a while back, and got no answer, regarding the fan motor for the in-cab heating and de-mister. This is the motor that sits in the engine compartment and turns the fan that blows the air over the element and into the ducts. Mine is burnt and I cannot find a replacement as there are few breakers here and even less Defenders to break (they last for ever). If anyone can help me locate a new or used motor I will gladly send the cost and beer tokens for service. The other problem I have is that the rubber seals on the base of the brake fluid resevoir are leaking - sometimes alot and sometimes not at all but they are leaking and usually when the LR is left standing rather than during use. Does any one know where I can lay my hands on some new seals as here they sell only the complete booster + resevoir as one part and for crazy money. Any help much appreciated. TIA Adam Quote Link to comment Share on other sites More sharing options...
orange rover Posted April 2, 2009 Share Posted April 2, 2009 Been away for a while - well actually just in-active and/or lurkingI did post a while back, and got no answer, regarding the fan motor for the in-cab heating and de-mister. This is the motor that sits in the engine compartment and turns the fan that blows the air over the element and into the ducts. Mine is burnt and I cannot find a replacement as there are few breakers here and even less Defenders to break (they last for ever). If anyone can help me locate a new or used motor I will gladly send the cost and beer tokens for service. The other problem I have is that the rubber seals on the base of the brake fluid resevoir are leaking - sometimes alot and sometimes not at all but they are leaking and usually when the LR is left standing rather than during use. Does any one know where I can lay my hands on some new seals as here they sell only the complete booster + resevoir as one part and for crazy money. Any help much appreciated. TIA Adam i am getting rid of my heater unit quite new - runs well (for dfender standards anyhow) http://forums.lr4x4.com/index.php?showtopic=40566 if you want it --> pm cheers ulf Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 2, 2009 Share Posted April 2, 2009 The seals come with the reservoir bit, about 20 quid from most online vendors. It's part # SJJ100351 and it looks like this: As for the heater blower motor you need to tell which of the 2 Defenders you need it for (200 or 300 series) and if it's a RHD or LHD (probably) as they are different (4 versions in all). Quote Link to comment Share on other sites More sharing options...
NegevLandRover Posted April 3, 2009 Author Share Posted April 3, 2009 The seals come with the reservoir bit, about 20 quid from most online vendors. It's part # SJJ100351 and it looks like this: As for the heater blower motor you need to tell which of the 2 Defenders you need it for (200 or 300 series) and if it's a RHD or LHD (probably) as they are different (4 versions in all). Thank you very much. The Defender is a 1997 300 TDI LHD - the blower sits in the right hand side wing. Adam Quote Link to comment Share on other sites More sharing options...
NegevLandRover Posted April 3, 2009 Author Share Posted April 3, 2009 i am getting rid of my heater unitquite new - runs well (for dfender standards anyhow) http://forums.lr4x4.com/index.php?showtopic=40566 if you want it --> pm cheers ulf That would be fantastic - but judging by the post below your post your unit probably would not fit as I have a LHD and yours is I believe RHD ? Thanks anyway Adam Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 3, 2009 Share Posted April 3, 2009 The seals also come in the various kits (which would be cheaper). Les. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 3, 2009 Share Posted April 3, 2009 The blower motor assembly is part # UTP1910. HERE is one place to buy it from (genuine or Britpart) - you'll be paying the price without VAT. Quote Link to comment Share on other sites More sharing options...
orange rover Posted April 3, 2009 Share Posted April 3, 2009 That would be fantastic - but judging by the post below your post your unit probably would not fit as I have a LHD and yours is I believe RHD ? Thanks anyway Adam mine is LHD - i live in Austria - unit sits on the right (passenger side) cheers spec Quote Link to comment Share on other sites More sharing options...
