Mean Green Posted April 2, 2009 Share Posted April 2, 2009 Will 235/85/16 BFG trac edge fit on a standard p38? Cheers Quote Link to comment Share on other sites More sharing options...
q-rover Posted April 3, 2009 Share Posted April 3, 2009 I run 265.75x16 on my P38. But the set up isn't standard. You will probably have problems with rubbibing unless you recalibrate the suspension heights. 265.70x16 and 245.75x16 work without recalibrating. Quote Link to comment Share on other sites More sharing options...
Escape Posted April 3, 2009 Share Posted April 3, 2009 Will 235/85/16 BFG trac edge fit on a standard p38?Cheers The should fit, if you don't have mudflaps. I run 265/75R16 on a standard setup, and only very slight rubbing, mostly due to the width. At normal height, all should be fine as long as you don't flex too much. At highway height, you might have to be a bit carefull when taking speedbumps and cornering at the same time. If you plan to use the car offroad, I'd suggest longer shocks and GENIII airbags, so you have more flex in the higher settings. The standard setup actually has better flex at normal height then offroad, which will cause rubbing with the bigger tyres. Quote Link to comment Share on other sites More sharing options...
