will 235 70 r16 wheels fit defender 110
235/70R16 is a tyre size rather than a rim size - I guess you are talking about built up wheels with that size tyre on? - they will probably be off a Discovery I should think.
They will fit assuming the rims are the correct stud pattern (do you have any photos of the type of rim?) but they will look a bit silly on a 110 with that size tyre on - however the alloys (which will probably be 7x16) will be fine with the "correct" size tyres for a 110 - either 235/85R16 or 265/75R16
They look to me like they are wheels off either a RR p38 or a Discovery 2 (which would fit with the tyre size you quoted), in which case those alloy rims won't fit your 110 - wrong PCD (distance between the studs) and wrong stud size too unless you use hub adaptors which are £££
