Rear axle oil leak
Its possible you dont need to change a seal. I had oil leaking at the wheel and at the drain plug, I bought a new breather which is the size of a nut and sits on the top of the axle. Pressure no longer builds up due to heat and the oil is no longer looking for an escape route. Easy job that cost about a pound. Worth a try.
 Share
