task Posted April 6, 2009 Share Posted April 6, 2009 I've been drawing a blank here really, I tried the search function but didn't find what I was looking for. I don't really want to use the internal EFI Rangey pump on my series but I'm not sure what to replace it with. Has anyone done this and what was the outcome? Quote Link to comment Share on other sites More sharing options...
cactus Posted April 6, 2009 Share Posted April 6, 2009 I've used a Ford XR3i/Sierra 2.0i/Granada inj pump on mine... Also Astra injection pumps work fine. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted April 6, 2009 Share Posted April 6, 2009 As cactus says any pump from a 2 litre+ engine. Preferably bosch. Efi pumps dont suck so you will probably need a non efi pump to feed it. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 9, 2009 Share Posted April 9, 2009 I've been drawing a blank here really, I tried the search function but didn't find what I was looking for. I don't really want to use the internal EFI Rangey pump on my series but I'm not sure what to replace it with. Has anyone done this and what was the outcome? What's wrong with using the efi pump in the series tank? I used an RRC efi pump (metal tank type) when I put the efi in my 90. I had to lengthen the pickup pipe a small amount (can't remember how much), but it works absolutely fine. After all it has to pump less distance now. The pump to tank fixing holes were exactly the same position and size. I THINK the series tank shares this hole pattern, ready to be corrected... Quote Link to comment Share on other sites More sharing options...
task Posted April 9, 2009 Author Share Posted April 9, 2009 Cheers for the replies My problem lies in the fact that I'm not using the series tank. I'm going to try and fit the RRC pump this weekend rather than splash a fortune on other methods so we shall see! Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted April 9, 2009 Share Posted April 9, 2009 I ended up cutting the flange from the RR tank and then welding it over a suitable sized hole on the series tank. Insert suitably lengthened RR pump, job's a gudun. Quote Link to comment Share on other sites More sharing options...
