bushtrekker Posted April 7, 2009 Share Posted April 7, 2009 I'm trying to renew my speedo cable, but the drive at the transfer box won't go in, does anyone know if there are different sizes of square ends for a 110? Cheers, John Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 7, 2009 Share Posted April 7, 2009 No you probably just need to spin it around a little to get it to engage - AFAIK all are the same and you can even shove one of the later type electronic speedo senders into an old transfer box Quote Link to comment Share on other sites More sharing options...
western Posted April 7, 2009 Share Posted April 7, 2009 the drive gears are a common size for the cable square end, it must line up right or it could snap the end off. Quote Link to comment Share on other sites More sharing options...
Prith Posted April 8, 2009 Share Posted April 8, 2009 the drive gears are a common size for the cable square end, it must line up right or it could snap the end off. Mine too is broken, but according to the parts manual there are two types of speedo cables, one a single piece and the other one a two piece, how does one know which is the correct one. IS there any way the cable is locked into the gearbox so that it does not come out? Quote Link to comment Share on other sites More sharing options...
western Posted April 8, 2009 Share Posted April 8, 2009 use a single piece cable. PRC6022 at the greabox end the cable fits in the speedo drive gear shaft & is held by a U shaped plate that has a 10mm hex head bolt securing the plate to the gearbox casing. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted April 8, 2009 Share Posted April 8, 2009 does the defender use a square cable end or is it just squashed into an oval? Any help appreciated Dave Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 9, 2009 Share Posted April 9, 2009 LT230 is square cable end. The drive mechanism can be just levered out and is in two pieces. Perhaps there's a bit of the old cable still in it? Les. Quote Link to comment Share on other sites More sharing options...
western Posted April 9, 2009 Share Posted April 9, 2009 couldn't be any clearer than above Quote Link to comment Share on other sites More sharing options...
Prith Posted April 14, 2009 Share Posted April 14, 2009 couldn't be any clearer than above U bet, thanks for the info on the cable Quote Link to comment Share on other sites More sharing options...
JimSlater Posted August 8, 2017 Share Posted August 8, 2017 Same problem here... missing that retainer clip. Found the part on ebay, but not sure what bolt/nut that is.. Anyone know of a part number? Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2017 Share Posted August 8, 2017 it should be a stud & nut, stud 571536 plain M8 washer & a suitable M8 nyloc nut. Parts bok doesn't show numbers for these 2 items Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted August 8, 2017 Share Posted August 8, 2017 It's M6 not M8. 1 Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2017 Share Posted August 8, 2017 23 minutes ago, nickwilliams said: It's M6 not M8. ah, yeah , didn't check the part number info, good spot. Quote Link to comment Share on other sites More sharing options...
