Froggie Posted April 7, 2009 Share Posted April 7, 2009 After losing the 3 Amigoes for about 6 months, they have finally returned and dont seem to want to leave anytime soon. Without going in to everything I did to get rid of them previously, it might be easier to say what i didnt do...... I was following an excellent tech sheet kindly sent from CIPX2, but as it was dark and raining i decided to omit one of the steps, which was "Check the earth tag". My question is does anyone know which is the earth tag for the ABS as there seems to be many of them!!! Thanks Steve Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 7, 2009 Share Posted April 7, 2009 The word "tag" doesn't show in the tech sheet. Can you be more specific, which of the earth connections you don't find? Quote Link to comment Share on other sites More sharing options...
Froggie Posted April 8, 2009 Author Share Posted April 8, 2009 The word "tag" doesn't show in the tech sheet. Can you be more specific, which of the earth connections you don't find? You are correct it is called a ground stud C0561-1, I think I got confused with another job which appears to be an Earth problem Would you know where C0362 is located, it just says it mentions LH side of Facia (Glove box i am presuming??) Thanks Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 8, 2009 Share Posted April 8, 2009 The figure 1 in the TSB shows where the C0561 is but mind that the air box is removed. Here's a picture with the air box in place, red arrow points to C0561: As for C0362, its in the passenger compartment, under the dash, high on the LH inner fender, see fig. 2 in the TSB Here's another diagram with the earth points: Quote Link to comment Share on other sites More sharing options...
spencerwilliamson Posted April 15, 2009 Share Posted April 15, 2009 I was following an excellent tech sheet kindly sent from CIPX2, but as it was dark and raining i decided to omit one of the steps, which was "Check the earth tag". Steve, any chance of a copy of the tech check sheet please? Mine have come on and I have it booked in to be read next Thursday. unless I can fix them before. Anyone bought one of the fault code readers from that guy in the states? I am tempted but it will only read the SLABS ecu not like a Rovacom. cheers Spencer Quote Link to comment Share on other sites More sharing options...
Froggie Posted April 18, 2009 Author Share Posted April 18, 2009 I was following an excellent tech sheet kindly sent from CIPX2, but as it was dark and raining i decided to omit one of the steps, which was "Check the earth tag".Steve, any chance of a copy of the tech check sheet please? Mine have come on and I have it booked in to be read next Thursday. unless I can fix them before. Anyone bought one of the fault code readers from that guy in the states? I am tempted but it will only read the SLABS ecu not like a Rovacom. cheers Spencer Spencer i will PM it now to you. I got a NANOCOM and I think its and excellent peice of kit. Steve Quote Link to comment Share on other sites More sharing options...
