white90 Posted April 7, 2009 Share Posted April 7, 2009 To get a piece of 160x80x5mm I'd have to buy a length of 7m 1.7m is enough for a x member so there'd be enough for 4 if I can get 3 others to commit I can order a length it would equate to £37 each. I'm looking at getting mine fabricated ready to be used dependent on some investigation work. of just keep it in the garage ready for when I need it. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 7, 2009 Share Posted April 7, 2009 Have you thought about phoning some metal works / steel stockists locally to see if they have an off cut ? http://www.yell.com/ucs/UcsSearchAction.do...3330010&M=0 Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted April 7, 2009 Author Share Posted April 7, 2009 yes and no joy Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted April 7, 2009 Share Posted April 7, 2009 How about somewhere that will sell you lengths of your choice? It might work out a little more per unit mass, but it'll be oodles cheaper than using a quarter of a length. Something like metalsupermarket? Al. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 7, 2009 Share Posted April 7, 2009 I've been here, I have the remainder of a 7m length! Only trouble is its in North Staffs! So, I don't want to tread on your toes Tony, but if you/anyone else prefers, I have three 'crossmembers' in stock, so to speak. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 7, 2009 Author Share Posted April 7, 2009 I'll have one bit and can sort some sort of delivery how much?? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 7, 2009 Share Posted April 7, 2009 I'll dig out the invoice when i get in, and divide it up. I'll let you know. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 7, 2009 Author Share Posted April 7, 2009 Thanks I need 1.7 meters to extend the x member to cover the Tub sides as they have been cut a bit. Quote Link to comment Share on other sites More sharing options...
hoarebag Posted April 7, 2009 Share Posted April 7, 2009 I could do with a 1.7m-ish bit too. I work in the Midlands so could probably bring two bits to Dorset (or somewhere between) and you could come and get the other bit from there or wherever? When do you need it? I'm back most weekends but not this bank holiday. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 7, 2009 Share Posted April 7, 2009 £35 a 1.7ish length. I've also got anti-crush tube by the 6m length, so short lengths of that are available if it's to anyones' liking. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 7, 2009 Author Share Posted April 7, 2009 Emailed you and Hoarebag Dorset would be ok As I'm sure a relay of sorts can be arranged Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 7, 2009 Share Posted April 7, 2009 What's the profile measurements of the anti-crush tubing Luke? Les. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 7, 2009 Share Posted April 7, 2009 The tube I have is seamless, 15.88 x 2.03 intended for 10mm bolts, and 19.05x2.03 intended for 12mm bolts. Quote Link to comment Share on other sites More sharing options...
zim Posted April 7, 2009 Share Posted April 7, 2009 ouch @ having to buy a full length ! if you don't get sorted by someone else, i'm a bit out of your way (Manchester) but we get whatever size / lengths of steel we want from our local guys. Gordon Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 7, 2009 Share Posted April 7, 2009 It's not so ouch when you can hopefully pass it on to other friendly forum members If this opportunity hadn't popped up, it was going in to either a press frame, or the base of a new welding table, so either way it's not really a problem. Since buying it as a 7.6m length, I've found a much friendlier stockist, who'll supply part lengths, and has scrap bins that you're free to root around in. bonus Quote Link to comment Share on other sites More sharing options...
zim Posted April 7, 2009 Share Posted April 7, 2009 true, i see you're listed as congleton..... i get my steel from Kenyons in Macc (or a place near Handforth), a small family run business that are dead friendly G Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 7, 2009 Share Posted April 7, 2009 A. D. Hall in Tunstall are the guys i talked about above, familar run too. Also, ASD have a depot in Biddulph. I've moved house since i was in Congleton, now nearer Kidsgrove. The better half works in Macc though. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 8, 2009 Author Share Posted April 8, 2009 Thanks to Luke and Hoarebag I'm sorted so won't be purchasing 7.6 mts of box section Now a forum relay from Dorset to Somerset Quote Link to comment Share on other sites More sharing options...
