JBorges Posted April 7, 2009 Share Posted April 7, 2009 After converting my tailgate to a normal door I need a fog lamp rubber protector like the picture. Anyone have one extra spare? Used or New? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 7, 2009 Share Posted April 7, 2009 Never seen one there before - but my 109 is a pickup so, who knows? Anyway - it kind of looks like a bumpstop for an Isuzu Trooper, perhaps it would work? G. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted April 7, 2009 Share Posted April 7, 2009 Or put a checkstrap on the door. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 8, 2009 Share Posted April 8, 2009 Or put a checkstrap on the door. Doesn't the door come with a check stop? I must look at mine. I'm sure the protector isn't standard. G. Quote Link to comment Share on other sites More sharing options...
sotal Posted April 8, 2009 Share Posted April 8, 2009 Mine never had a rubber protector. Just the check strap which stops the door opening that far Quote Link to comment Share on other sites More sharing options...
JBorges Posted April 8, 2009 Author Share Posted April 8, 2009 I have half door not a safari door. Quote Link to comment Share on other sites More sharing options...
western Posted April 8, 2009 Share Posted April 8, 2009 could use the rear door check bar & brackets from a 90 or 110 SW or hardtop, the door frame is common so it shouldn't be to hard to fit. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted April 8, 2009 Share Posted April 8, 2009 i think most original if not all series with rear doors had them, mine does. I'm sorry though, i havent a clue where to get one. Maybe use a bump stop? Quote Link to comment Share on other sites More sharing options...
JBorges Posted April 9, 2009 Author Share Posted April 9, 2009 This rubber protection is a standard on a SW's. If I find one on a junkyard... Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 9, 2009 Share Posted April 9, 2009 This rubber protection is a standard on a SW's.If I find one on a junkyard... I've looked through the parts manual, and optional parts manual and can't find it, sorry. Went through the defender book too, no sign. Mind you - I may have missed it. There is an internal stop mechanism, though.# G. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 9, 2009 Share Posted April 9, 2009 My 109, despite coming with a rear door, door mounted spare and fog light from the factory, never had one of those protector buffers. I don't think it needs one, if the door's check/stay rod is working correctly (there should be a rubber block in the door track, which will allow the door to over-open if missing. Personally, I think those buffers are damned ugly, and I'd imagine they may be hard to find. Check the door stay rod is correctly fitted and then try opening the door to see if the spare wheel can hit the lamp. If not, then you have no need for the buffer. Quote Link to comment Share on other sites More sharing options...
