Aragorn Posted April 8, 2009 Share Posted April 8, 2009 Ok i'm looking to replace my steering rods as part of my rebuild, and i figure i may as well buy some fat ones while i'm there as i'd be replacing the track rods and then getting the stock ones blasted and powder coated anyway... So, ive seen that paddock do some for about 65quid which seems pretty reasonable. Are there any others people would recommend or are these paddock items half decent? Thanks Quote Link to comment Share on other sites More sharing options...
crwoody Posted April 8, 2009 Share Posted April 8, 2009 I fitted Sumo bars to mine a while ago after an unfortunate incident with a big rock A lot stronger than the original weedy things - they will support the weight of the car so you could jack the car up off them if you really wanted to. I replaced both the drag link and the track rod on mine, I got them from - http://www.ekmpowershop2.com/ekmps/shops/c...-bars-125-p.asp Don't know about the Paddocks ones though. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 8, 2009 Share Posted April 8, 2009 I got mine from paddocks and im happy with them good price and they do the job simple as that Quote Link to comment Share on other sites More sharing options...
Dave W Posted April 8, 2009 Share Posted April 8, 2009 Been using the Britpart HD ones on mine for a year now, put them on for the 2008 Outback Challenge. As well as doing the OBC I've done challenge events and trials in Ireland and the UK since and they are still in good, straight condition. I don't use a steering guard either so they are pretty much on their own. Got mine from Devon4x4, I suspect the Paddocks ones will also be Britpart. Surprisingly, considering they are Britpart, the track rod ends that came with the bars are also still in good condition ! Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 8, 2009 Share Posted April 8, 2009 I have a set of the HD bars they take some pritty hard knocks although I have bent one The TREs arent bad either they have been on a year and they are still ok! Not bad for britpart! Dave. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted April 8, 2009 Share Posted April 8, 2009 I spent a bit more and went to qt services instead. Don't know if they are any better but since they were only one and a half times the price it was worth doing. Quote Link to comment Share on other sites More sharing options...
Outdoor Ed Posted April 8, 2009 Share Posted April 8, 2009 The Paddock ones are ok at £65 but if buying them I would go for the option of the better ball joints, only problem if that they then cost you £95 Or as an alternative option Mail Order 4x4 do some, with better quality greaseable ball joints for £72.50 Quote Link to comment Share on other sites More sharing options...
lansalot Posted April 8, 2009 Share Posted April 8, 2009 I got a pair of Sumo's from www.4allfours.co.uk - they are close to me, and I was able to go see Ian and pick them up. He straightened them for me when I bent them too. While a lot stronger than normal, don't presume a tree stump won't bend them pretty badly if you catch it the right way, so consider a bash plate as well. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 8, 2009 Share Posted April 8, 2009 I've got the paddocks ones, they are OK but I have managed to bend the trackrod (got stuck on top of a tree stump) Quote Link to comment Share on other sites More sharing options...
lansalot Posted April 8, 2009 Share Posted April 8, 2009 I bent both (track rod first, straightened by Ian) and then the drag link (replaced, too far gone). To protect the track rod, which is lower, I fitted this superb bit of kit. http://www.gwynlewis4x4.co.uk/page29.html Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted April 9, 2009 Share Posted April 9, 2009 The Paddock ones are ok at £65 but if buying them I would go for the option of the better ball joints, only problem if that they then cost you £95Or as an alternative option Mail Order 4x4 do some, with better quality greaseable ball joints for £72.50 I have the Paddocks H/D rods too. Tho' it is worth mentioning i bought the ones with supposidly standard ball joints and the items they came with are good quality and have grease nipples too. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 9, 2009 Author Share Posted April 9, 2009 It does look like they are reasonable parts, unlike most paddock/britpart items which i hear endless carp about, these seem to be pretty decent, so i think i'll plump for a set. They'll need to wait until i get my swivel rebuild kits etc, as theres not much point fitting steering rods before i dismantle the hubs and swivels, but will go on the ever growing list. Thanks Folks Quote Link to comment Share on other sites More sharing options...
Ruuman Posted April 11, 2009 Share Posted April 11, 2009 I've got the paddock ones with the OEM TRE's, very nice and strong. you need to remove the diff guard thing to make the fit don't forget lots of copper slip on the TRE threads Quote Link to comment Share on other sites More sharing options...
