Steve Warman Posted April 8, 2009 Share Posted April 8, 2009 Hi, I have a 2.5l petrol and every time i get in a get a faint whiff of petrol in the cab. It then gets worse if I have the window and vents open. During its time with me I have changed the carb but nothing to drastic. Does anyone have any idea what, if anything, could be wrong with it and if there's anything I can check to make suure I'm not riding around in a bomb? Thanks Steve Quote Link to comment Share on other sites More sharing options...
oakesy Posted April 8, 2009 Share Posted April 8, 2009 Hi,I have a 2.5l petrol and every time i get in a get a faint whiff of petrol in the cab. It then gets worse if I have the window and vents open. During its time with me I have changed the carb but nothing to drastic. Does anyone have any idea what, if anything, could be wrong with it and if there's anything I can check to make suure I'm not riding around in a bomb? Thanks Steve You may have a small leak near the carb. Check while on your pathway and feel around fuel connections. Also you could be running rich. Check the carb overflow outlet pipe if leaking carb float sticking. Check fuel line is not perished . Check fuel tank is not damage or leaking. hope this help Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted April 8, 2009 Author Share Posted April 8, 2009 You may have a small leak near the carb. Check while on your pathway and feel around fuel connections.Also you could be running rich. Check the carb overflow outlet pipe if leaking carb float sticking. Check fuel line is not perished . Check fuel tank is not damage or leaking. hope this help Cheers Oaksey, I'll be out there tomorrow checking these things out Quote Link to comment Share on other sites More sharing options...
dirkthe1 Posted April 8, 2009 Share Posted April 8, 2009 if its none of those could it be unburnt fuel and old exhaust? correct me if im wrong Quote Link to comment Share on other sites More sharing options...
