jcwcooper Posted April 8, 2009 Share Posted April 8, 2009 Quick question im planning to upgrade the alternator on my 200tdi. Obviously i need to upgrade the wiring and im planning to use around 90-100amp alternator, I have had a look on VWP website and cant find any 100amp cable, can you use 2 legnths of say 50amp running to and from the same place? Cheers Dave. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 9, 2009 Share Posted April 9, 2009 Get some 4 gauge cable and run it all the way to starter main lug. Remove the existing 2 wires. See a welding shop for cable and terminals. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 10, 2009 Author Share Posted April 10, 2009 Is 4 guage the only option? Dave. Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted April 10, 2009 Share Posted April 10, 2009 Nothing wrong at all with running 2 lengths instead of 1 if cost is an issue. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 10, 2009 Author Share Posted April 10, 2009 Just thinking crimping the ends maybe a problem with anything over 6mm2 Dave. Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted April 10, 2009 Share Posted April 10, 2009 Theres always the soldered type if you cant lay your hands on a crimper. Decent blow torch will suffice. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 11, 2009 Share Posted April 11, 2009 Go to a welding store, they will crimp the ends for you. IMO, it makes more sense to "do it right" with one properly sized wire and be done with it. Quote Link to comment Share on other sites More sharing options...
Garthy Posted April 11, 2009 Share Posted April 11, 2009 What uprated alternator are you going for? I've just diagnosed my alternator and feel an uprated one would be suitable because I use a split charger, however searching on the tinernet I can only find the 45 & 65 amp type. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 11, 2009 Share Posted April 11, 2009 It is possible to modify certain 100 Amp 300TDI (AMR4248) alternators to fit the 200TDI Defender. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 12, 2009 Author Share Posted April 12, 2009 Im going for a Ford mondeo 90 amp one. there is a thread on here about it somewhere 300tdi Alternators are quite expensive and mondeo ones are plentiful Dave. Quote Link to comment Share on other sites More sharing options...
