Ibex94 Posted April 10, 2009 Share Posted April 10, 2009 Hi All, Does anybody out there in Brstol / Somerset have an extended reach 32mm socket I could borrow? Am rebuilding my R380 and have got to the point where I need to remove the 5th ratio lay gear and found I need an extended socket. Any help much appreciated. Regards Rob Quote Link to comment Share on other sites More sharing options...
white90 Posted April 10, 2009 Share Posted April 10, 2009 When I needed an extended 52mm socket I just cut the one I had and put a piece of box section in the middle and welded it back up. Quote Link to comment Share on other sites More sharing options...
51bigG Posted April 10, 2009 Share Posted April 10, 2009 When I needed an extended 52mm socket I just cut the one I had and put a piece of box section in the middle and welded it back up. Yep, I did them same with 2 sockets, 24 & 30 with a bit of pipe and use them regularly with 110 impact gun. Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted April 10, 2009 Author Share Posted April 10, 2009 Thanks guys I've got some scaffold tube and will give it a try tomorrow Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted April 11, 2009 Author Share Posted April 11, 2009 Being bank holiday my usual tool shop closed was driven to the doors of Halfords Pleasantly surprised by the range of tools they now carry including full range of extended sockets 1/2" drive up to 32mm! Rob Quote Link to comment Share on other sites More sharing options...
western Posted April 11, 2009 Share Posted April 11, 2009 a good result then their 'professional' range of tools is quite well regarded & has a good warranty to. Quote Link to comment Share on other sites More sharing options...
