110 rear coils....which ones are a little stiffer
Prob been asked before but which springs to go for if towing a trailer without going for very heavy duty ones. I've seen defenders with trailers on and they always seem a little low at the back.
Mine are heavy duty and toooooo stiff as the back end only drops an inch with 2+ tons on the trailer.
It's a very hard ride when empty so what is a compromise please :)
You should only have a load of about 75kg on the towball whatever the load on the trailer. The load should be taken on the trailer springs/wheels, NOT those of the towcar.
You can tow another 110 on a trailer without making the towcar look loaded if the load is correctly distributed and the towbar setup correctly - ball at the right height being the main issue.
Chris
If it drops an inch with a good load in the trailer that sounds about right to me. Absolute max noseweight is 150kg I think, which is not a lot.
Its scary how many people here totally ignore noseweight and correct setup e.g. running a twin axle Ifor Williams horsebox onto a towball mounted on the crossmember not on a drop plate, all the weight on the rear axle and the rear suspension of the vehicle down about six inches, there's a couple of those around! Overloading the back makes it too light on the front wheels and downright dangerous.
Negative noseweight is even worse news... especially with a 50mm ball.
