mabbs Posted April 13, 2009 Share Posted April 13, 2009 Hello My 92 3.9 v8 R/R has partially lost its PAS. When turning initially there is no assistance, yet when movement has been initiated on the wheel there is some assistance, albeit very jerky. I am have replaced and tighten the PAS drivebelt, to no avail (although when I had this problem in the past it was a slipping belt). Is this likely to be the pump or the belt? Any suggestion, greatly appreciated! Rich Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 13, 2009 Share Posted April 13, 2009 More likely a low fluid level allowing air into the system -you don't mention you have checked this... Top it up and with the wheels jacked off the ground turn from lock to lock a few times to get the air out the system, then re-try it under load. Quote Link to comment Share on other sites More sharing options...
mabbs Posted April 13, 2009 Author Share Posted April 13, 2009 good point - I did check the level was a little low, but I will certainly bleed as suggested and see if this remedies it. Thanks Richard Quote Link to comment Share on other sites More sharing options...
